DFplayer mp3 speaker out (which is + or -)
Account cancelled 2017-07-21 08:05:54 2729 Views1 Replies hello.
I'm using the DFplayer module to play some audios on system start-up. However, I want to mix the audio with a line-in from another device.
The line in from the other device comes with Left, Right and Ground. But the MP3 Player only has 2 outputs, it doesn't specify which is + or which is ground so I mix the proper signal with the Right Channel and the other one with the ground channel.
Can anybody help me out? cheers
2017-08-02 00:13:58 For earphones, normally you only need the left, right DAC and GND, you can have a look at the attached pic
robert.chen
robert.chen
