DRI0023 Stepper motor shield(DRV8825) with encoder?
hoepin.cu.psb 2017-08-14 10:12:07 2973 Views2 Replies Dear all,
I would like to ask if it is possible to allow the encoder to determine the position of the stepper motor using the DRI0023 shield. I intend to use gray code to program the motor to stop and turn as I want or as the condition requires. Most probably I would be using NEMA 11 and NEMA 17 Stepper motor.
2017-08-25 01:17:32 Why do you want to add an encoder to the step motor, since by measuring the number of pulses, you can get the position of the step motor
robert.chen
robert.chen
