Speech Synthesis shield DFR0273 - Arduino hangs after the first sentence pronounced
Account cancelled 2017-08-23 11:15:20 3611 Views3 Replies Hello,
I have a big trouble with my Speech Synthesis shield on an Arduino Mega2560. I have checked the power source is powerful enough and memory available for the sketch is huge.
Here my speech definitions :
What is wrong ? Any idea ?
Best regards
Here my speech function:
byte voiceJarvisArmor = 0;
char volumeLevel5[] = "5\0";
char answerJarvis_defaultMode[] = "the armor is switched to default mode\0";
char answerJarvis_initCompleted[] = "the systems are initialized. the armor is fully functional\0";
here the main loop and setup :
void ttsJarvisSays (byte voiceType, char ttsJarvisSentence[]) {
byte ttsJarvisBuffer[500];
SpeechSynthesis.buf_init(ttsJarvisBuffer);
SpeechSynthesis.English(ttsJarvisBuffer,4,volumeLevel5);
SpeechSynthesis.English(ttsJarvisBuffer,6,ttsJarvisSentence);
SpeechSynthesis.Espeaking(0,voiceType,4,ttsJarvisBuffer);
while(Serial.read()!=0x41)
while(Serial.read()!=0x4F)
The first sentence is properly pronounced, but nothing after "ttsJarvisSays (voiceJarvisArmor,answerJarvis_initCompleted);" is executed. The Arduino seems to be hanged.void setup(){
Serial.begin(9600);
ttsJarvisSays (voiceJarvisArmor,answerJarvis_defaultMode);
Best regards
2019-08-14 23:35:30 Hi,
Can you try commenting both
while(Serial.read()!=0x41)//waiting synthesis complete
and
while(Serial.read()!=0x4F)//waiting play complete
And then check the result. I checked libs that it seems that there is no 0x41 and 0x4f would be written in serial, which means it will be stuck in the while loop forever.
xuegangxiao117
and
xuegangxiao117 2019-08-13 03:21:27 Hi, I have the same problem:
this works (in setup)
infoatphp
and this doesn't send the execute command (led remains on, and shield 'busy' led remains off)SpeechSynthesis.buf_init(ssr);//Clear the buffer
SpeechSynthesis.English(ssr,4,"5");//volume in grade 5
SpeechSynthesis.English(ssr,6,"Booting up");//"6" means synthesis in English; "cooki"is the content
SpeechSynthesis.Espeaking(0,16,4,ssr);//Executive commands above, "0" is synthesis command; "19" select speaker; "4" speech function
SpeechSynthesis.English(ssr,4,"9");//volume in grade 9
Found any solution? SpeechSynthesis.buf_init(ssr);//Clear the buffer
SpeechSynthesis.English(ssr,6,"Okay");//"6" means synthesis in English; "cooki"is the content
SpeechSynthesis.Espeaking(0,19,4,ssr);//Executive commands above, "0" is synthesis command; "19" select speaker; "4" speech function
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
infoatphp
