DFPlayer signal to arduino question
Account cancelled 2017-08-27 10:55:09 2698 Views3 Replies Hello,
I have the dfplayer working with the ardiuno, i can push some buttons to hear some jingles.
Its works fine, simply when a button pressed, it send commando myDFPlayer.playFolder(2, 2); to play the second file in map 2, great.
But i have a other thing, also there is a music playing on a musicaudio player to arduino, works fine, when i pressed the sample button for the dfplayer, its send first a command:
setvolume(0) so the music from the other musicaudio goes to volume 0 (mute)
after that the dfplayer is playing file 2 from map 2.
But when the jingle is stopt, then he must send a command setvolume(10) back to the arduino to turn the music volume up.
Its like the blue led on the dfplayer, its on when its play a file, and wil be off when the file has be end/stopt.
So what can i use the send the arduino the command setvolume(10), how trigger i the command from the dfplayer?
Or is a connection from the led to one of the pins from the arduino a option?
I hope someone can explane me.
Thanks allot.
Kinder regard
Marcel
Thanks allot.
Kinder regard
Marcel
2017-09-29 01:57:03 The wiki of the DFPlayer uses the software serial, even follow this, the module not work?
robert.chen
robert.chen 2017-09-25 18:31:47 Although the SoftwareSerial is not working for me. Even using a 3.3v arduino or the 1K resisitor.
Anyone else having this problem?
Tweeks
tweekstemp
Tweeks
tweekstemp 2017-09-25 18:29:16 Use pin 16, the _BUSY signal. It is what will tell the arduino something is playing (active low).
Tweeks
tweekstemp
Tweeks
tweekstemp
