X-Board v2 and Pachube data on LCD
synekvl 2012-04-22 00:09:34 8108 Views3 Replies The described project reads feed data on Pachube and shows them on LCD. The project is quite simple. I've used following HW:
- DFRobot X-Board v2 (DFR0162)
- DFRobot FTDI Basic Breakout (DFR0065) for uploading the sketch code to X-Board
- LCD2004 display
- i2c / SPI character LCD backpack by Adafruit (www.adafruit.com/products/292)
- DFRobot USB Power adapter (FIT0107)
- USB cable for power, Ethernet cable to connect it to router/internet
The connection between X-Board and LCD is serial using four wires only. Of course, you may use also the parallel connection without Adafruit (or other) adapter but it uses much more X-Board pins. Information on wiring you may find here: http://www.ladyada.net/products/i2cspilcdbackpack/
So we have the hardware, now it is time for software. To compile your code you need:
- Arduino IDE, the latest version is 0023 now
- Pachube library ERxPachube available here: http://code.google.com/p/pachubelibrary/ (note: please download and install library version compatible with your IDE, i.e. for IDE 0023 is the latest version ERxPachube-I-2.5.zip)
- LCD LiquidTWI library by FalconFour can be found on http://hostfile.org/LiquidTWI.rar, the forum topic http://forums.adafruit.com/viewtopic.ph ... 6&p=113177
The sketch code:
Code: Select all/* Demonstration sketch for X-Board by DFRobot ( http://www.dfrobot.com/index.php?route=product/product&filter_name=dfr0162&product_id=564 ) and Adafruit i2c/SPI LCD backpack using MCP23008 I2C expander( http://www.ladyada.net/products/i2cspilcdbackpack/index.html ) The circuit: * 5V to X-Board 5V pin * GND to X-Board GND pin * CLK to X-Board #5 * DAT to X-Board #4 */ // include the library code: #include <ERxPachube.h> #include <Ethernet.h> #include <LiquidTWI.h> #include <SPI.h> #include <Wire.h> #define PACHUBE_API_KEY ".............." // fill in your API key PACHUBE_API_KEY #define PACHUBE_FEED_ID ..... // fill in your PACHUBE_FEED_ID unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds const int postingInterval = 29500; // delay in [ms] between updates from Pachube.com String data[5]; // My sketch is for 5 streams. Enter YOUR number of datastreams you will be recovering from Pachube. // Standard ERxPachube library is set for 4 streams only. If you need more go to the file ERxPachube.h // and change #define MAX_DATASTREAM_NUM x to meet your requirements byte mac[] = { 0xCC, 0xAC, 0xBE, 0xEF, 0xFE, 0x91 }; // make sure this is unique on your network byte ip[] = { 192, 168, 2, 9 }; // set your own IP address ERxPachubeDataIn datain( PACHUBE_API_KEY, PACHUBE_FEED_ID ); LiquidTWI lcd( 0 ); // Connect via i2c, default address #0 (A0-A2 not jumpered) void setup(){ // set up the LCD's number of rows and columns: lcd.begin( 20, 4 ); // depends on your LCD type, I use 2004 LCD Ethernet.begin( mac, ip ); delay( 100 ); lastConnectionTime = postingInterval; } void loop(){ if( millis()-lastConnectionTime > postingInterval ){ int status = datain.syncPachube(); String stat = char(status); GetDataStream( datain ); lcd.clear(); if( status != 200 ){ lcd.setCursor( 20 - stat.length(), 0 ); // if connection to Pachube is NOT OK then status "number" is shown in upper right corner lcd.print(status); } else { lcd.setCursor( 19, 0 ); lcd.print("."); // if connection to Pachube is OK (status code=200) then "." is shown in upper right corner } // set the cursor to column 0, line 1 // (note: line 1 is the second row, since counting begins with 0): lcd.setCursor( 0, 0 ); // FIRST row - Outer temperature lcd.print("Outer:"); lcd.setCursor( 13 - data[3].length(), 0 ); lcd.print(data[3]); lcd.setCursor( 13, 0 );lcd.print(char(223));lcd.print("C"); lcd.setCursor( 0, 1 ); // SECOND row - Inner temperature lcd.print("Inner:"); lcd.setCursor( 8, 1 ) ; lcd.print(data[0]); lcd.setCursor( 13, 1 );lcd.print(char(223));lcd.print("C"); lcd.setCursor( 0, 2 ); // THIRD row - Names of another three values lcd.print("Press"); lcd.setCursor( 9, 2 ); lcd.print("Trend"); lcd.setCursor( 16, 2 ); lcd.print("Accu"); lcd.setCursor( 0, 3 ) ; // FOURTH row - atm.pressure, trend and accu voltage values lcd.print(data[1]); lcd.setCursor( 11 - data[2].length()/2, 3 ) ; lcd.print(data[2]); lcd.setCursor( 17, 3 ) ; lcd.print(data[4]); lastConnectionTime = millis(); } if( millis()-lastConnectionTime > postingInterval/2 ){ // in the half of posting period the Units are shown in THIRD row instead on value's names lcd.setCursor( 0, 2 ); lcd.print(" hPa Pa/Hr mV"); } } void GetDataStream( const ERxPachube& pachube ){ unsigned int count = pachube.countDatastreams(); for( unsigned int i = 0; i < count; i++ ){ data[i] = ( pachube.getValueByIndex(i) ); } }
I recover all 5 values from Pachube: Outer and inner temperature, atmospheric pressure and trend of its changes, and LiPO accumulator voltage. My Pachube feed is 25574, so you may check it on Pachube's site.
The sketch is very simple. The ways how to display the values on LCD is endless so take my layout as an idea only. If you have any questions don't hesitate to contact me either here or on synekvl AT gmail DOT com
Have a nice day
Vladimir
Thanks again for the great contribution. I must apologize for the confusion caused by the sample code posted in the community. There is a problem with the code highlight provided with wordpress. It keeps changing the "<" and ">" symbols.
I think I finally fixed the problem. I have updated the code as well.
Cheers!
Hector I went through IDE 1.0, I had to search little bit on the internet, but finally I got compiliable code. Can you replace the last one in community blog, please ??
Modified code for Arduino IDE ver. 1.0
The circuit:
* 5V to Arduino 5V pin
* GND to Arduino GND pin
* CLK to Analog #5
* DAT to Analog #4
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <SPI.h>
#if defined(ARDUINO) && ARDUINO >= 100
#define printByte(args) write(args);
#else
#define printByte(args) print(args,BYTE);
#endif
#define PACHUBE_API_KEY "................" // fill in your API key PACHUBE_API_KEY
String data[5];
byte ip[] = { 192, 168, 2, 9 }; // no DHCP so we set our own IP address
const int postingInterval = 30000; // delay in [ms] between updates from Pachube.com
ERxPachubeDataIn datain(PACHUBE_API_KEY, PACHUBE_FEED_ID);
//void PrintDataStream(const ERxPachube& pachube);
LiquidCrystal lcd(0);
lcd.begin(20, 4);
Ethernet.begin(mac, ip);
delay(100);
GetDataStream(datain);
lcd.clear();
lcd.setCursor( 20 - sizeof(status)+1, 0 );
lcd.print(status);
else {
lcd.print(".");
lcd.setCursor( 12 - data[3].length(), 0 );
lcd.print( data[3] );
lcd.print(data[0]);
lcd.print("Press");
lcd.print("Trend");
lcd.print("Accu");
lcd.print( data[1] );
lcd.print( data[2] );
lcd.print( data[4] );
if( millis()-lastConnectionTime > postingInterval/2 ){ // THIRD row shows Units instead of values
char buf[ data[4].length()+1 ];
data[4].toCharArray( buf, data[4].length()+1 );
int volt = atoi( buf );
if( volt < 340 && millis()%2000 < 1000 ){ // voltage value blinks every 1sec when less than 340
lcd.setCursor( 17, 3 );
lcd.print( " " );
else {
lcd.print(volt);
for(unsigned int i = 0; i < count; i++){
data[i] = pachube.getValueByIndex(i);
That's all from my side.
Cheers
Vladimir
synekvl I have nothing against the modification of my contribution. Thanks to your modification I finally got a courage and I installed IDE version1.0. But here the problems start - I installed IDE 1.0, all libraries as you changed, I took your modified code and:
1. there are missing libraries in all #include statements
2. there are characters as "&&" instead "==" and ">" instead of ">" (the last is not only in arduino version statement but also further in the code ...)
3. did you try to compile the code in IDE 1.0 ?? I can't compile it as IDE 1.0 takes in different way than previous ver.0023 string conversions in two places of the code. I can't do that without change of the code.
Please check / change above items as I would like to avoid any misunderstandings in future if someone will be willing to use this project ....
synekvl
