APC220
jaroslaw 2014-04-26 05:05:42 9943 Views9 Replies Hello and SORRY FOR MY POOR ENGLISH !
The datasheets you provide concerne APC220-43 or APC220 V.3 or APC220 V.2
APPCON says about APC220-43 or APC220-47 or APC220-A
I received your APC220 product with written RF7020 V4.0 (i now what is 7020)
What is the real datasheet applicable to the product i received
And i would like precisions for characteristics (RF power, use of MUX pin, when are bytes pulling 'on the air',
when are exchanges beetwin the module and my controler, ...)
A clear and good datasheet is necessery for a good programming
Thank yoy
Thank yoy
2014-06-17 04:24:19 Communication, sir
I just want answers for points 1, 2 and 3 for my post 31 mai
before code my program who verify if my verifying program verify correctly the communication
You speak french ? ;D
jaroslaw
jaroslaw 2014-06-11 02:54:20 [quote="jaroslaw"]
The answer my friend, is blowing in the wind . . .
[/quote]
HAHA this is always a good answer ;D ;D ;D ;D
I think you should send the parameters using HEX instead of ASCII ?
Jose
[/quote]
Jose 2014-06-01 03:13:36 Hello
More questions now . . . in my best english . . .
1 - To setting parameters on-line from a µC I sent 19 bytes
2 first bytes are W h'57' R h'52' and 2 last bytes are CR h'0D' LF h'0A'
and parameters are between
Is it OK ?
2 - Setting parameters are ASCII coded on 7 bits
Must I send bytes parameters like this : start bit 7 bits ascii code stop bit
or like this : start bit 1 bit at zero 7 bits ascii code stop bit
3 - During running operation I send bytes like this : startbit 8bits stopbit
OK ?
Thank you
jaroslaw
Is it OK ?
OK ?
Thank you
jaroslaw 2014-04-28 18:44:03 Hello Jaroslaw,
Sorry for the confused. It is APC220-43.
The frequency range of the APC220-43 is about 433MHz. 418~455MHz.
And the datasheet is correct. You could follow the guide, using RFmagic to set the parameter.
If you still have any question, you could write them here.
Grey.CC
Grey.CC
