LP 3 DeltaArduino
[DISCUSSION] LattePanda in Car
userHead lextar 2016-06-08 05:18:14 78014 Views29 Replies
Hi all,
I want to install lattePanda in my car and create my own 2 din headunit.
I just need if it is possible to power on the board using the ignition switch (+12v).
It would be nice to power the board from the battery and use the ignition switch signal instead of the power button. Is it possible ?
Thank you
Alex
