LCD connector missing
userHead lion_heart69 2016-08-28 00:11:58 4458 Views5 Replies
As a backer No. 128 I recently received LattePanda 64GB / 4GB.
Immediately I used it with HDMI interface and it worked very fine.
After summer vacation, on 22 august 2016, I needed to use LattePanda with LCD interface and I discovered that LCD connector on LattePanda PCB is missing (not mounted or detached), there are only soldered pins.
In attachment you can see this inconvenient.
In the meantime I ordered another board from DFRobot (Order ID: 69914) cause I need it urgently.
What I have to do with this missing connector? I can’t solder SMT connector.
Thank you for a kind reply
Riccardo
