Another LattePanda CarPC Project
Dougal 2016-12-14 01:48:57 14707 Views7 Replies Hello All,
I have built a LattePanda CarPC that I intend to use for datalogging and flash tuning my car with.
https://www.youtube.com/watch?v=Pmv6SyGUg3g
I've had the unit working well already with a power adaptor to the ciggarette light socket but for proper power on/off i have purchased a DCDC-USB. Intelligent buck-boost DC-DC converter with USB interface.
Has a large Input voltage range (6-34V) and Programmable Output range (5-24V)
Applications: power for motherboards with single rail power from any voltage to any voltage, laptops, custom electronics with buck-boost DC-DC
Programmable via USB interface
Sends ON/OFF pulse to motherboard
4 modes of operation: DUMB, Automotive, Script or UPS
This allows me to configure Power On/Off timers that are ignition sensed.
This means i don't have to worry as much about data corruption from power on/off via the car key.
Right now i am working on loading the new BIOS to the LP and so to not require power on/off from the LP power button. Once that is done then i need to wired up the DCDC-USB device to a 12volt power line that is always active and then wire up to ignition wiring for the trigger.
