My 7" 3d Printed Alpha Tablet
anonymous 2019-03-26 21:47:51 17480 Views4 Replies I used this 3d printed file from thingiverse by sgtsmall.
https://www.thingiverse.com/thing:3317867
The side and large panel is not needed.
I had the modify the backplate with a dremel tool so that I could fit the battery in. I removed the piece of plastic around the red box.
Battery purchased from
https://s.click.aliexpress.com/e/cP0wTi6y
I had to extend the 3 black wires so that I could bend the wires back just a little further, so I combined the 3 black wires together to a thicker wire (thats all I had at the moment). Then soldered it on the board where the 3 wires was soldered at.
I had to use a longer screw in the bottom right mount to support the corner of the backplate. It did not have any support before.
I will add double sided adhesive or velcro to the battery and the backplate.
I know its a little thick. I would like to slim it down sometime in the future once I upgrade to a bigger screen. I know its not perfect but it works for now.
