Question for LattePanda Alpha Battery Users
userHead akhibhrat58 2020-12-22 02:05:35 1901 Views1 Replies
If you have a battery connected to your LattePanda Alpha through the 10 pin battery connector, can you change that battery by applying 12V to the 4 pin JST power connector? I know the battery will charge if you apply power through the USB-C port, but I'm curious if the same applies when applying power through the JST connector...
