streaming cable network cable unplugged
exceedstar 2022-06-30 02:51:10 1699 Views0 Replies I tried the desktop-to-desktop interconnection using the streaming cable I bought, but failed.
I used the program downloaded from the guide, but the ip of the Ethernet connection that should be output as 1.1.1.1 was output as 0.0.0.0 for some reason.
I didn't really know what the problem was, so I looked through all the configuration files.
And I found that in Network Connection, The 'Remote NDIS compatible Device' is Network Cable Unplugged.
Of course, both of my desktops have male and female USB 3.0 ports plugged into each.
I want to know if there is a solution to this situation, or if the product is a malfunction due to aging because it is an item that was received as an additional accessory funding when funding Kickstarter.
