Technical Discussion
Lattepanda Alpha / Delta Fan connector type
userHead janis 2024-02-20 11:40:57 1627 Views8 Replies
I see that there is a 2 pin connector for the Fan. I want to replace with Noctua nf-a4x20 . This one has 3 pin connector. On the internet i found 3 pin to 2 pin connector.
But the 2pin is very different then what's on the board.
What is the name of fan connector and what cable adapter do you advice ?
Best.
