Lattepanda Mu, Will there be 16GB version?
janis 2024-04-14 03:27:41 2488 Views4 Replies Hi,
I believe the LattePanda Mu would make an excellent new board. However, I'm not entirely certain about one aspect: its compatibility with the Intel N100 86x processor. This might allow it to run TrueNAS.
The minimum requirement for TrueNAS is 8 GB of RAM, but I suspect that performance might not be optimal with this configuration.
Given that the processor can support up to 16 GB of RAM, the question arises: Will there be a 16 GB option, and is there enough space on the board for it? From what I've seen, the board appears quite compact, which could be a concern.
Best,
