Find the Windows 10 Product Key on your LattePanda
userHead Harris.Qqo 2024-06-14 22:45:08 3091 Views3 Replies
Hi guys,
If you own a LattePanda device, you might be aware that many of their products come with Windows pre-activated. However, since there's no physical key provided, it can be worrisome to lose your activation code during tinkering or system modifications. Here's a quick guide to retrieve your Windows activation key should you need it.
Step 1: Access Command Prompt
1. Press the `Windows key + S` to open the search bar.
2. Type `cmd` into the search bar.
3. Right-click on the `Command Prompt` result and select `Run as administrator`. This step ensures you have the necessary permissions to execute system commands.
Step 2: Retrieve the Activation Key
1. Once the Command Prompt window is open, type or copy and paste the following command:
wmic path SoftwareLicensingService get OA3xOriginalProductKey
2. Press `Enter`. This command queries your system for the Microsoft product key that is associated with your Windows installation.
After executing the command, your Windows activation key will be displayed in the Command Prompt window. Make sure to note it down and keep it in a secure place for future reference.
Remember, this key is important for your software's authenticity and should be kept confidential. Only use it for legitimate purposes such as reactivating Windows on your LattePanda device if necessary.
