What is the output of this sensor? Do I need an external pull-down resistor for output?
JaneYu 2024-12-02 16:40:25 996 Views1 Replies What is the output of this sensor (SKU: SEN0395)? Do I need an external pull-down resistor for output?
2024-12-31 16:40:52
JaneYu
Supports GPIO output, supports serial port output, and does not need pull-down resistors when outputting, and can be directly connected to the main control board.
JaneYu
