How Long Does the Probe Need to Be Calibrated for Analog Electrical Conductivity Sensor K=10?
JaneYu 2024-12-04 17:20:48 1193 Views1 Replies How long does the probe need to be calibrated for the Analog Electrical Conductivity Sensor K=10?
2024-12-31 17:21:16
JaneYu
The calibration interval is determined by the frequency of use. Normally, you can calibrate it once a month. If used frequently, it can be calibrated once a week. When calibrating, fresh standard buffer solution is recommended.
JaneYu
