What to Do if the Analog Electrical Conductivity Sensor Does Not Read or Gives Inaccurate Readings?
JaneYu 2024-12-04 17:28:45 1884 Views1 Replies The sensor does not read or the reading is inaccurate. What could be the reason?
2024-12-31 17:29:09
JaneYu
1. Please check your sensor version and select the correct Wiki (the library file code of K=1 and K=10 version sensors are different);
2. Please clear the epprom of the board and re-upload the Wiki sample code and calibrate;
3. Please use a hot hair dryer to heat the adapter board and re-measure to exclude the influence of moisture on the sensor.
4. If the above method still cannot be used normally, please contact our email address:techsupport@dfrobot.com
JaneYu
