BE CAREFUL: this part DOES NOT FIT an Ultimaker Original!!!
userHead Tonny12138 2015-01-27 18:48:05 230 Views1 Replies
BE CAREFUL: this part DOES NOT FIT an Ultimaker Original!!! The dimensions are off in every way: the hole for the tube is 6.0mm (6.4mm originally) the filament hole is 3.3mm (3.2mm), the upper part outside diameter is 8.9mm (10mm), the lower part outside dia is 6.05mm (6.35mm) and the dept of the lower part is 5.9mm (5.05mm).
So this part won't even fit the PFA tube that dfrobot sells...
At least it was marginally cheaper than the OEM part :) :(
2015-01-28 16:57:23
Thanks for the feedback. We will look into this issue right away. If this not fit your application. Please let us have you order number. We will replace yours.
userHeadPic Tonny12138
