Hello,I have a question about the equation that posted with the sample code for SEN0098 sensorreadings[index] = (readings[index]-510)*5/1024/0.04-0.04;can anyone please discribe to...
userHead JaneYu 2015-03-13 20:30:05 19 Views6 Replies
can anyone please discribe to me what each number mean?
thanks in advanced
2018-09-28 18:44:03
Hi everyone,
i want to measure DC solar current and have currents around 35A , up to 42A. We will use 32mm² wires. How do you recommand to solder the thick wire to the sensor board?
Best Regards,
Lucas
You may need to use a high power solder iron.
2018-10-08 13:48:10
2018-07-14 16:33:15
i have this for 50 A sensor .sensor zero current raw output in ardiuno is 508 and suddenly change it to 509 or 507 .. is their any solution ?
2017-03-21 18:30:32
Hi Daniel, did you refer to the wiki to do a test?You also connect a DC motor, right? Normally, the no-load current is about less than 1A.
2016-08-16 18:12:36
Does anybody know how to securely fix an AC load through this sensor? I would like to use this sensor in a product but need to make sure it is electrically safe.
Thanks for the help.
What 's about this one? http://www.dfrobot.com/inde...
2016-08-19 18:44:59
