Whats the chances of this board getting POE support to power the whole board in the near future?
userHead JaneYu 2015-04-12 14:16:54 46 Views16 Replies
2020-10-26 03:39:15
I changed to Google WIFI Mesh, Have connected the board to the WIFI through cable. Google mesh is not able to find the board in the Google WIFI mesh app. I`m able to connect tho the Xboard through a computer that is connected to the same network. Google can not find anything wrong with the Google wifi mesh network. As long at the app is not able to find the Xboard, I`m not able to forward outside trafic to the Xboard. Any fix on this, exept from connecting an other router to the network and connect the Xboard to this router instead of directly to the google mesh?
2019-04-08 09:36:20
i wonna buy some xboard relay, but it's out of stock.
when can i buy this board.
2017-08-01 09:33:09
You can refer to the softwareSerial library on Arduino website, normally, it means that you can use some pins(for Leonardo, there are only some pins available for softareserial) as serial pins, the functions are same with the hard serial
https://www.arduino.cc/en/R...
2017-07-31 09:53:05
It seems that this board don't have the hard serials, you can try to use software serials for the communication
2016-11-19 04:21:41
Our company have an ERP(Delphi ) and have project for an 7 motels company (700 rooms) . We need control all electric power supply room (lights room, air conditioned, tv etc) integrating ERP with XBoard Relay . We need operate the XBoard with ERP.
2016-11-16 22:20:03
Please is avalaible libraries or code samples for integrate Delphi programmming language ?
2016-09-28 02:45:04
Yes, the only way to use it is from usb power or 7/9 Volts from DC power connector. More than 9 Volts It becomes too hot.
2016-07-05 11:55:11
yes, it works with 5V via USB port.
Thanks for the answer. The problem is that is not so stable with 9V and 12V from DC plug.
So the question is, Is there some hardware power issue form that side? Stop to works after few seconds.
I have the same problem from both XBoard.
2016-07-05 15:45:31
2016-06-08 18:39:15
Hi, there is a case already. http://www.dfrobot.com/inde...
2016-05-23 15:36:35
Whats size is the power supply inlet? 2,1mm?
2015-04-15 20:11:13
Maybe the next version, POE power supply is very popular now
And when is next version comming, it's now 3 years later and still no POE. Now it's no longer popular, now it's a De facto standard ;-)
2018-02-22 22:16:19
