i use this shieldthis shield used sw spi? hw spi?if sw spi how can i change hw spi?i want add sd card module in case of SD+LCD shield only SD module operatehow can i operate bot...
JaneYu 2015-10-21 00:17:24 23 Views3 Replies i use this shield
how can i operate both this shield and sd card module
2015-10-21 17:47:26
JaneYu
HI, you could take a look its wiki. It is using SPI interface. And for SPI interface, there is a CS port, You could change your target via change this pin
JaneYu 2015-05-15 09:50:03
JaneYu
Yeah, it is compatible with UNO, since the screen get power from 3.3V port.
JaneYu
