Hi,can use 9V battery directly supply voltage to the sn-mq9 sensor? or have to use voltage regulator to step down to 5v?
userHead JaneYu 2015-11-24 21:30:09 21 Views2 Replies
2015-06-23 13:39:45
Here the anwser to myself, i found a good project to use this sensor and how to get the value in ppm
http://www.dfrobot.com/inde...
2015-06-18 18:38:06
Hi, this is sensor analog value, you could check its datasheet for the characteristic curve
