Hi, I buyI bought a shield, but is not working. I put the sample project, but does not work, replace the name of the APN, username and key ... any help?
userHead JaneYu 2015-06-18 23:44:50 19 Views14 Replies
2016-08-27 11:55:44
hello, i have problem with convert distence from degrees to kilometers or meter?? have you solution?? thankyou
2016-05-21 00:39:34
i have a problem with send message,, my message its never come to my phone ?? have you solution ??
It requires a send command, you can input "0x1A" in the serial monitor,(Not recommand Arduino IDE, it can't send HEX character manually)
2016-05-27 14:46:57
2016-05-06 22:04:34
Alguém tem o código para arduino?
HI, check the product wiki, you'll get it
2016-05-27 14:45:08
2016-05-06 20:39:57
I'm having problems with reading of GPS.
I'm developing a project which only uses GPS. But I found no tutorial which explains how to use only GPS to Arduino. I need help. The original program compiles to UTC and after that to.
2016-04-08 18:26:02
Please check the satellite number, generally it requires 4+ satellites to make an accurate coordinates. If I am right, the this chip support 2.5m accuracy. Try it outside
2016-01-29 13:50:12
Hi, you link has been broken. this is a shield based on SIM908, so you need a SIM908 library. And RX&TX will be D0 & D1
2016-01-12 17:50:46
We need a SIM CARD to use GPS or not?
2015-12-28 16:29:23
Hi, I need some information about shipping. How much does it cost for shipping to Turkey?
2015-12-04 16:02:28
Yes, you could take a look its AT command manual.
2015-11-30 15:01:15
Hi, I am sorry, no. But there are some sample code on the wiki page.What function do you need?
I wanted to activate GPRS, thanks for your reply
2015-12-01 02:41:24
2015-10-21 17:17:40
Don't forget 3 driver pins, you could connect them via jumper caps. Anyway, you will require an external power, since GSM shield will requires more current.
