Hi, my motor shield doesn't work. is there any code i can download to test the board work well?
JaneYu 2015-06-25 01:43:21 17 Views3 Replies Hi, my motor shield doesn't work. is there any code i can download to test the board work well?
2016-05-03 19:02:33
JaneYu
Check this one, http://www.dfrobot.com/inde... This shield supports pin defination, you can stack two shields together on your UNO.
JaneYu
