HiWhat shield for Arduino Uno R3 should i use together with this one ?
JaneYu 2015-08-29 23:37:06 18 Views12 Replies Hi
Has anyone successfully driven this with an arduino uno? I can't get mine to work at all.
JaneYu I need Mechanical drawing or document or manuel
JaneYu Please email [email protected] about these documents
Can it work with 3.7V battery?
JaneYu I don't think so, you'd better use the Arduino with 5V working voltage
Hi, for this kit, an I/O expansion shield will be OK. http://www.dfrobot.com/inde... If you need more servos (over 10), you could consider servo driver board.
JaneYu Yes, I mean that one.
I just receive my kit and ... I can't mount it, exactly the same problem Rob has.
I try with an old DF05BB bought previously and it fits perfectly.
The size of the servo is exactly the same but the fixation is not on the same position.
I'll post a picture later.
JaneYu Hi,I got this kit from DF recently.I didn't have this problem.And i notice that you didn't put the bearing cup in
Maybe you pull the bracket open when you instill it when step 4?
There 's my suggest: put the bracket in the right place first then put the servo in and scew it. And the distorted bracket ,I think you can push it in :)
JaneYu Hi Rob, do you have any flat head screw, which could replace round head screw? If the head has been small a little, is that OK with bracket?
JaneYu Hi, that won't change the fact that the tilt bracket is too wide for the distance from the servo disc to the bearing cup...
One of what ? servo? If the goods you recieved does not the same as SHIPPING LIST,you can contact [email protected].
And which bracket? I suggest you take some pictures and post the question in the DF forum. : )
JaneYu
