Hi i am building a quadcopter for which i am using APM 2.6 as the flight controller. I just wanted to ask if i can use this gamepad with 2 xbee pro modules. One on the transmitter ...
userHead JaneYu 2016-02-05 00:02:22 13 Views11 Replies
Hi i am building a quadcopter for which i am using APM 2.6 as the flight controller. I just wanted to ask if i can use this gamepad with 2 xbee pro modules. One on the transmitter side(inside the gamepad) and one on the receiver side (to the flight controller) will it work? Please i need a fast reply
2017-03-23 08:40:51
Hi, Is it possible to use this gamepad with Bluno Bee ( https://www.dfrobot.com/pro... ) ?
And control more than one device with BLE Micro ( https://www.dfrobot.com/pro... ) at the same time? (I meen that more than one BLE Micro receive input from gamepad at the same time)
2017-03-22 23:56:18
Would this Controller work with EV3 mindorms lego robot?
2016-09-16 19:39:56
Will this controller work with HC-05/06 bluetooth modules considering they use SPP bluetooth profile?
2016-05-22 23:35:14
The problem was from the boot loader. I burnt new boot loader for the gamepad via another arduino. Then, the board can be uploaded as usual.
2016-04-12 04:25:17
but only one xbee on leonardo can communicate easily whit pc?
2016-04-11 19:49:19
I there! Thanks for reply. There is a chance to have the source-code(libs, sample sketch etc) and the list of the components that you had use, of your product? I need to make a joystick by myself, and this is kind amazing!
2016-04-05 17:51:28
hi, it's Wifi Bee ESP8266 supported by this gamepad ?? Thank you.
2016-03-03 13:55:42
You need to turn the power switch off, if you want to connect to USB with batteries power supply
2016-02-26 15:26:47
Hi. Does this gamepad support Xbee PRO S2B (series 2B)
2015-09-11 18:10:15
Oh, sorry. Please check this link. It should be the lost link. http://www.dfrobot.com/inde...
2015-08-21 10:42:32
Hi, it depends your communication method. for example, you want to use bluetooth, then you will need two bluetooth bee, one in the gamepad; one on your car. This is just example, wifi; zigbee, RF are all OK. Since it is using Serial communication. the code could be very easy. (It also could be very difficult), you could search some Arduino serial example on the net.
