Hello Can I use this module with Leonardo ?
userHead JaneYu 2015-08-27 07:04:27 8 Views9 Replies
2016-06-07 16:40:38
Hi, you can update to the lateset Bluno Firmware and try to use the "AT+SETTING=DEFAULT" to reset it
2016-06-02 17:02:03
i desold HumTemp IC D2, R14, R23 for resolve some conflict between I2C display and HumTemp, RGB Led. But display dont work. If i take single oled i2c display and connect GND, +5V, SCL, SDA to my Leonardo dispaly will show correctly. Sketch at Leonardo ok.
Hi, the shield I2C interface is connecting to the I2C port beside D13, But it is still a problem. there is compatible issue with Leonardo, (works on UNO) not sure the reason, we'll keep an eye on it.
2016-06-07 18:17:36
2016-06-01 17:30:44
i use Leonardo with this shield. I install blunoAccessory and U8glib libs. And try run examples for blunoAccessory.
Buzzer, Temp&Hum, Joystick, Knob, relay, RGB are work OK. But display dont work correct!
When i run AccessoryShiledDisplay sketch i can see many random white dots at display and flashing of blue channel at RGB led. Flashing 9 times.
Where is problem? Brocken display or error at U8glib?
I try U8glib 1.18.0 version and upgrade 1.19.1...
2016-02-16 10:02:03
Hi, you can power it from the under Arduino board
2015-11-02 19:26:45
According to the schematic, you don't need to remove RGB led, since it is free if you don't use it. but D2 will be a problem, I remember DHT11 is default high, it means it will interfere with the interrupt
Thanks for the swift response. I guess I can still use the red and green led channels while keeping the blue channel deactivated?
2015-11-03 21:34:00
2015-08-27 07:06:01
Can I use this module with Leonardo?
Yeah, it is compatible with Leonardo.
2015-08-27 19:11:50
