What is the difference between the SKU DRI0009 and SKU: DRI0017?They both use the same L298P chip, they both support UNO. they seem from photos to be completely the same.Which one ...
userHead JaneYu 2015-10-08 15:29:27 17 Views2 Replies
Which one should I buy?
2016-06-17 23:52:13
Can I use this with a biopolar stepper motor?? If I can How connect the port?
2015-10-10 18:15:43
The motor drivers are different. if you doesn't motor driver or it is the first time you use it, I'll recommend you to use DRI0009, if you already have one, and you want to control another two on the same board. I'll recommend "twin"
