can I disable bluetooth modul or use 2 uart devices at the same time (for example, built-in bluetooth module + uart gps module)? Thanks.
userHead JaneYu 2015-11-19 04:23:17 578 Views1 Replies
2015-11-20 14:35:40
Hi Tomofey, as a serial device, it could be replaced by the other device. just pay attention to the serial interface voltage. And I have to make a tip, if you hack the module, it will loss warranty.
