These things are great! They work perfectly. I build arduino based DMX control consoles that use this board and have had no problems with them at all. I came here to order anoth...
JaneYu 2015-12-23 04:20:11 4 Views11 Replies These things are great! They work perfectly. I build arduino based DMX control consoles that use this board and have had no problems with them at all. I came here to order another one but unfortunately they're out of stock.
Hi there. Using Arduino Mega 2560 I need to control more than 1 DMX universe. How can I do with this shield ?. Or I need to stack several shields controlling each universe ?. Thank you.
JaneYu Hi, i bought one of this to using as DMX Slave. I connected Arduino + DMX Shield on DMX Controller (Cyber128) but i cannot read data from controller. I tested reading with a LCD display with I2C. I used serial port for DMX Shield
JaneYu hi, I would like to buy 70 pics. How long will it take to prepare? Is it OK to send abroad?
JaneYu No. Neither the seller nor DFRobot was able to assist in any way in regards to this issue. I'm starting to believe there's a bad batch of them out there or at least poor customer service.
JaneYu Would this DMX shield work with these boards? LPCXpresso11U37(OM13074) and LPCXpresso1549(OM13056) They both have the arduino piggyback connectors. I understand that i will have to develop the library's myself since these boards are equipped with ARM Cortex M0+ en M3 processors.
JaneYu Is the pin displacement the same as Arduino's? because the DMX connector is send signal by TX/RX, the pins on LPCXpresso should support this.
Hi, is it possible to use the shield for DMX purpose and IR remote control at the same time?
For example: using an Arduino Uno with a WS2812b led stripe makes it impossible to be controlled by IR. A way around in this case is connecting two Arduinios, i.E. Uno and Nano. The Uno controls the WS2812b, the Uno controls the IR.
Thanks in advance
Leo
JaneYu i am wondering how the shield receives an address from DMX-512 controller? do we have to set the address by Arduino?
JaneYu HI, you can check the "Documents", there is a DMX library and other resource for the shield
Hi, please click the yellow button "Notify me" to inform you, once it comes back. anyway, it is very good if you could share your project.
JaneYu
