What type of connection does the display have? (ex. VGA?, HDMI?)
userHead JaneYu 2016-03-06 21:50:21 8 Views22 Replies
2016-08-24 11:46:47
you can use 2 displays at the same time, so using the integrated touchscreen and the HDMI is fine. with windows 10, I even got the integrated display and a wireless one working at the same time.
2016-08-04 09:24:50
I think he wants a 5" display that plugs into the internal connector, not one that uses HDMI. He wants the HDMI cable to be open for connecting external monitors. I'm in the same boat, I want a 5" screen for this as well so I can make a small SteamOS portable.
That's exactly what I need I currently have a 5" screen but it uses the hdmi port ;(
2016-08-28 09:23:15
2016-07-29 19:37:15
I wanted to Make the latte panda portable enough to fit in your pocket but with the 7 inch screen you can't and having a hdmi cable to connect the screen not only keeps me from plunging it into another monitor but it also uses up a lot of room
2016-06-08 07:14:22
Its 16:10 or 16:9 aspect ratio?
2016-06-07 13:51:05
Is there a brightness rating for this monitor and what is the longest cable that can be used with it? Is there a 12 inch cable available? Thanks.
2016-05-23 04:26:36
Does the black side of the connector go up or down when plugging it into the Lattepanda? Also, I've found that it disconnects easily; is it supposed to, or am I connecting it wrong?
the black side of the connector go up ,and the Golden finger side down.Like the aplication picture shows
2016-05-23 11:42:43
2016-05-22 12:26:51
HI, Lattepanda team doesn't open too many devices, but we'll make more test with other screen to add its accessories
2016-05-19 20:44:24
Is this a touch display ? If no can we make it touch display by using the Capacitive Overlay ?
2016-05-19 06:01:46
Hello, i would like to know if it is compatible with a raspberry pi or a C.H.i.P/ does an addapter to HDMI exist, cuz i wanna use the same display for my latte panda and my rraspberry pi
2016-03-22 11:14:32
The cable appears to be very short. Is there a way to get a longer cable?
2016-03-16 08:09:52
Is the lattepanda compatible with any other diaplay out there? From what i read it uses a mipi 30 pin connector and i cant find any other display that uses that. Is it proprietary? Will other diaplay sizez be available? I already backed the enhanced version.
Hi,Paul.This display is only for the lattePanda.But we will provide more size of screen for LP in the future.
2016-03-21 12:06:35
2016-03-07 14:38:23
This display using FPC to connect with LattePanda
2016-03-07 12:27:42
are it have HDMI connect?
This display using FPC to connect with LattePanda. HDMI is on the LattePanda to fit general display
2016-03-07 14:39:34
2016-03-03 15:19:36
LattePanda has FPC connector to interface with this 7 inch screen.It's something useable on other devices.
And LattePanda has HDMI what makes it more widely applicable
