Hello I would like to know if this URM06 - RS485 Ultrasonic work in water to determine the distance.
JaneYu 2016-07-01 12:22:37 18 Views3 Replies Hello I would like to know if this URM06 - RS485 Ultrasonic work in water to determine the distance.
2017-01-10 01:01:13
JaneYu
Hello, is there a support for this hardware? I installed this sensor 6 months ago and it worked Ok until last weekend.
I have not easy access to the sensor and i need some help to check if this problem is software or hardware.
I can read temperature from it but I can not read distance.
JaneYu JaneYu
wrote:
2017-01-10 18:11:27 1 Replies
hi, you can check the raw value (HEX), if the return value is OK, then that is software problem
2016-07-05 11:34:19
JaneYu
I am sorry, it is not a waterproof Ultrasonic sensor. You can check these http://www.dfrobot.com/inde... and http://www.dfrobot.com/inde...
JaneYu
