The sample sketch is not correct. In this sketch when the flow drops, the flow keeps show the lastest and highest value of the flow in the sreial monitor
userHead JaneYu 2016-09-16 23:36:27 7 Views11 Replies
2023-05-19 13:56:15
Water Flow Range: 1-30 L/min
2022-06-08 17:08:24
good morning . My name is Roberto, I would like to know if it is possible to connect Gravity: Water Flow Sensor to a drinking water pipe? and if it is possible to connect an electronic liter-counter device to it. thank you
2022-01-12 19:45:52
What is the maximum range I can separate the Arduino from this sensor I have around 30 meters distance.
Long distances can cause a voltage drop across the connecting cable, which can affect readings. It is recommended to use Bluetooth or Wifi to transmit data for long distance detection.
2022-02-24 15:09:04
2020-06-23 04:31:45
Can be used to measure a river flow?
2020-04-15 09:44:34
What is the minimum pressure that the sensor can work correctly?
2019-11-24 01:13:58
is the sketch example totalized flow?
2019-08-18 12:23:11
Can i use water flow Sensor woith NodeMCU ?
2019-06-02 15:16:27
halo, is it possible to use two sensor in a time? Any change to the code?
2018-12-08 03:35:07
what is the maximum distance length for connecting with arduino?
2018-05-28 15:09:15
Hi, which board you use? UNO? The Input voltage should be >3.5V, please check it. And could you send us the video or picture to give us more information on your problem?
