Hi, when i connected this shield with Romeo BLE and with 2 servos DF05BB, after several turnings of the servos, the shield is reset. Do you have any ideas how to solve this problem...
JaneYu 2017-03-09 21:36:52 5 Views7 Replies Hi, when i connected this shield with Romeo BLE and with 2 servos DF05BB, after several turnings of the servos, the shield is reset. Do you have any ideas how to solve this problem. Is the power provided too low, i already tried with the LiPo battery 2 cells
Hi, I am guessing it should be related to power supply voltage. Whats your voltage of 2 cells? And where is your lipo battery connected to? The servo-pwr interface ?
JaneYu The voltage of the 2 cells Li-Po is 7.4V from DF robot and i connected it to the External Power Input, not to the Servo-PWR. I also think it is related to the power, because with 1 servos, the system is fine. I tried to connect 5V battery (the one use to charge handphone) directly to the Servo-Pwr but it doesnt work either, the 9IMU shield is still reset; the 2 servos work fine though. I havent figured out how to solve this yet. Should i buy a seperate shield for the servos with seperate power supply line so that the power supplied to 9IMU shield will not be interrupted ?
