109/5000Hi, I'm trying to connect two sensors for a one-line reading;How can I use both sensors ??
JaneYu 2018-03-29 00:01:56 10 Views6 Replies 109/5000
Sensor does not work with Arduino Uno WiFi rev2 error "No TCS34725 found ... check your connections" module can be found on 0x29 with I2c scan any ideas please.
JaneYu Hello, can you specify how many Kelvin are the white LED'S? I am doing a dissertation and hence this information is crutial!
JaneYu You can use this I2C address Multiplexer https://www.dfrobot.com/pro... it solves the problem of same I2C address conflicts.
JaneYu The outputs is not the raw RGB values, it uses getRGBC() function, and the outputs seem like color temperature in degrees.
JaneYu As I know, it seems we can try to adjust the 4 led color on the board to be used for backlight control. There is a LED pin of the XH2.54 (breadboard) interface.
JaneYu
