Hi, would like to double check on the working condition of the Relay. Currently using a way more costly relay with Raspi.Working conditions:230V AC wire,Normally Closed preferred (...
userHead JaneYu 2017-09-13 17:41:10 10 Views3 Replies
Working conditions:
230V AC wire,
Normally Closed preferred (The one I have is normally open, leading to additional wiring to ensure power is supplied to pi and risks of pi failure.)
Controlled by Raspi (I use more Raspi than Arduino)
10A is okay, but if you have higher current models would be welcome too.
Also, do you have anything similar for 48V DC?
2023-05-30 04:03:53
hi! Does this board have an optocoupler that fires the relay or is it connected directly?
2017-09-14 11:05:21
For the higher current model, this one satisfy your request https://www.dfrobot.com/pro..., while it's working under 5V, not fit for Rpi
2017-03-19 22:58:28
I am just doing some planning and looking around. I am looking for a solution with a latching relay and this product showed up in some advertisement or Google plus maybe. The picture with the Raspberry Pi Relay.png with the light bulb and the wall outlet is also misleading.
