If I need more digital and analog inputs and outputs than the Arduino provides, is this the correct board to purchase? Are the 16 additional I/Os capable of being PWM Digital and ...
userHead JaneYu 2017-05-06 04:13:23 337 Views1 Replies
If I need more digital and analog inputs and outputs than the Arduino provides, is this the correct board to purchase? Are the 16 additional I/Os capable of being PWM Digital and can they be Analog?
Thank you. Dave
2018-02-11 01:16:26
No, this does not add any additional inputs or outputs. It simply gives you more physical connection options to the I/Os (more flexibility with the pins). If you need more I/Os, consider using a different type of Arduino (such as the Mega 2560).
