How does the formaldehyde sensor in this package compare to the dedicated formaldehyde sensor (product 1574)? Which one is more accurate?
JaneYu 2017-09-12 12:28:38 9 Views12 Replies How does the formaldehyde sensor in this package compare to the dedicated formaldehyde sensor (product 1574)? Which one is more accurate?
it says "Particle Range of measurement: 0.3 ~ 1.0μm; 1.0 ~ 2.5μm; 2.5 ~ 10μm"
can it really read PM1,PM2.5 and PM10?
JaneYu another question.can use with esp8266?
JaneYu We haven't offered the basic code about the esp8266. If you want to do this, you could have a try. but I advice for you to use it in arduino serial production.
good morning, I need the library for the arduino, because when I compile the code, It show a error
JaneYu Which one is more accurate for sensing the particles concentration this one or the SEN0177
JaneYu I'm having a little difficulty with my code - trying to translate the Arduino example to Raspberry Pi Python... is there some example python code I can look at? :) I'm falling down with a struct.unpack statement, and I'm not even certain I'm on the right path.... (Arduino example code was perfect - thank you!)
JaneYu Hi,
It's a pity that we don't have any python code for this sensor, you can take a look of this blog, it uses Rpi to control an PM2.5 sensor, you can refer to its code and see if it would help. http://www.instructables.co...
Is it compatible with the Bluno Nano?
Product link: https://www.dfrobot.com/pro...
JaneYu It's compatible, it uses serial for communication.
