do you have a version with encoders?
userHead JaneYu 2018-08-28 23:01:26 8 Views6 Replies
2024-07-22 02:54:24
I am using 4:1 Metal Gear motor 25Dx67L mm HP 12V with 48 CPR Encoder
( https://www.pololu.com/product/4844) . Two of these fit nicely in the Devastator chassis. I have not looked extensively, but I expect there are very similar options available here through DF Robot, too.
2019-09-04 10:48:45
Hey Teymour,
We do not recommend changing the gears yourself. However, we do have a variety of gear ratio motors on our site that you could take a look at.
2019-04-24 16:25:04
Hello, I am looking for the datasheet of this motor. I'm looking for how fast this motor reaches its maximum no-load speed. Maybe a graphic that describes the behaviour of this motor? Thanks.
2019-04-08 23:16:27
At present, there is no suitable motor with encoder for Devastator.
Thank you for your Suggestions, which will be considered in the next version.
2018-08-28 23:17:18
2017-09-25 09:07:58
Yes, actually we have the Devastator with metal DC geared motor, this motor is the same for the one in that platform.
