Hi, can you tell me what the operating temperature range of this pump is in degrees Celsius? I'm asking because I'm looking for an immersible pump that can operate at temperatures ...
JaneYu 2018-01-29 22:13:49 9 Views8 Replies Hi, can you tell me what the operating temperature range of this pump is in degrees Celsius? I'm asking because I'm looking for an immersible pump that can operate at temperatures up to 96 degrees Celsius.
How can I make a flow rate control on this pump. PWm control doesnt work on it
JaneYu Hey, I put together a guide that walks through using this motor and an Arduino to make a plant watering system.
JaneYu Hello, what is the inner diameter, outer diameter, and the length of the water tube that comes with it?
JaneYu Hello, what is the inner diameter, outer diameter, and length of the water tube that comes with it?
JaneYu I am trying to use this pump for a small plant irrigation system, where the water level has to overcome about 1.5 meters before flowing downwards again. It is rated with a head of 2.2 meters, but I barely reach 1.2 meters (depending on barometric pressure) @12V. Anyone having similar challenges with this pump? What other low power pumps with more head are recommended, and are they available here?
JaneYu
