Incremental Photoelectric Rotary Encoder - 400P/R + DFRduino UNO R3 + Gravity IO ExpansionCan the measurement result be read with visual basic 6 program?Is it possible to use a rot...
JaneYu 2018-02-21 00:12:41 11 Views6 Replies Incremental Photoelectric Rotary Encoder - 400P/R + DFRduino UNO R3 + Gravity IO Expansion
Is it possible to use a rotary encoder type ENC-1-3-T-24 or ENC-1-3-N-24?
Can you share code VB ?
Thank & Regards,
2024-02-20 03:24:26
JaneYu
I have it connected to a heltec lora wan V3, with the same scheme as the image. but for some reason I have variations in the reading.
I think that the quality of my power supply is not good, which is recommended to avoid voltage variations.
I am planning to use a Decoupling Capacitors between the controller and the rotary encoder
JaneYu 2023-08-09 13:41:56
JaneYu
Can I get the CAD file as a STEP?
JaneYu JaneYu
wrote:
2023-08-11 16:25:54 1 Replies
Sorry we do not have the Dimension file for this product.
