Hello what is maximum node and speed(200m) on star network mode?
JaneYu 2018-04-11 08:57:43 7 Views9 Replies Hello what is maximum node and speed(200m) on star network mode?
Please I need urgently certificate of comfimity for LoRa Radio Module - 433MHz, SKU:TEL0116
JaneYu Hello there…
I would like to control a robot using it( vehicle robot ), in the same time to receiving the gas sensors measurements with raspberry pi. Is possible?
Thanks in advance
JaneYu For anyone trying to figure out how the hell to get these working. Connect the EN pin to ground!!! Also the AT commands are different to the MESH version
JaneYu I bought the LoRa modules and connected them to two arduino uno boards using for wires based on the usb to ttl converter pins. i created a simple arduino to test sending of data but nothing is happening in serial monitor. can you help?
JaneYu Hey Solomon,
I am sorry you are having some difficulties. Currently we would need more information to better assist you. I suggest emailing [email protected] with more specific information regarding the connections and code you are using, in this case pictures of your setup would help!
Great! Thank you very much, you're awesome. That solution could come integrated in a V7.2 ... a small switch (as the one for RUN/PROG) to select 'BT mode' vs 'RxTx mode', and you can use the BT/APC also for using those LoRa modules (interfaces). But its seems not easy to put new stuff to this master piece ...
JaneYu What do you want to use LoRa for? this EN pin is not required to connected for transmission. You just need to connect GND VCC and TX/RX for communication.
JaneYu I'm building a mesh/ad-hoc network with LoRa. In a STANDAR communication mode for this module, if I do not set the EN pin to GND, the node does not work/communicate (tried!). So, I need to know how to deal with the DTR pin to set LOW (to enable communications) and HIGH to disable the LoRa module.
.jpg)
