What if I just have a 3.3 volt PWM control signal?
userHead JaneYu 2018-03-27 20:51:19 11 Views7 Replies
2020-09-02 09:50:09
Hi there what is the stall current of these devices? I want to run them through a BEC on an ESC. Thanks
2020-02-24 10:25:12
What are the rpm's of each type of motor?
Hey, You could use the pulse to get the rpm.
2020-02-24 18:05:59
2018-10-03 02:13:20
How many grams is this product
2018-03-28 17:00:00
3.3V PWM also works since only duty circle controls, but you need to make sure VCC has over 3.5V power.
Hi Disqus,
Thank you so much for reply!
I have a last year version of the robot and I could not drive it using 3.3V PWM, but a 5V one works. Is it a *guarantee* that your motor this year will work at 3.3V? That is critical to my project.
Looking forward to your reply!
Regards,
Dawei
2018-03-28 17:14:01
Is 3.3V guaranteed? I have an old version and it does not work at 3.3V. Please double check because that is critical to me, thank you very much!
2018-03-28 17:19:59
