What's the field of view for this sensor?
JaneYu 2018-05-05 02:15:46 15 Views9 Replies What's the field of view for this sensor?
Is the MLX90614-DCI module equipped with a single-point medical-grade infrared temperature sensor, which can detect the temperature of objects with an accuracy of ±0.2°C in the body temperature range? Or it is only the MLX90614-DCC that can detect the temperature with an accuracy of ±0.2°C ?
JaneYu I2c non contact temperature sensor sen0206 used behind the metal surface
JaneYu Hey Kalpesh,
I am unsure if you are asking us if you can use the IR sensor behind a metal surface or not. Since this sensor is contactless , it is depedant on its FOV (Field of View) therefore if the metal surface is obstructing the FOV, the sensor will read the temperature of that metal surface and not an object behind it. Please take a look at the product wiki "Measurement Method" section here: https://wiki.dfrobot.com/IR...
Hi, how long would it take to receive it in the Netherlands?
LE: Nevermind, I found it
JaneYu Thanks for the interest! If you need any additional information about shipping, feel free to email [email protected] and they can give you exact details.
Yes, this sensor is controlled by I2C, you can use ESP8266 microcontroller to control it.
JaneYu Did you receive the cable like in the attachment? one side is connected to the senosr another is to the gravity pins. https://uploads.disquscdn.c...
JaneYu
