Hi, Can it be operated by a 8Mhz board?Thanks!
JaneYu 2018-07-30 00:19:08 7 Views12 Replies Hi, Can it be operated by a 8Mhz board?
Thanks!
We recommend you with this sensor:
We also have an onboard MCU on the sensor to run the heart rate algorithm.
JaneYu Sorry we only got the sensor that could measure heart rate and oxygen saturation.
You could take a look at: https://www.dfrobot.com/pro...
JaneYu I can it use on arduino uno board. But it didn't work on arduino yun board,when I run the digital mode ,the serial monitor showed nothing.
JaneYu Hello
I used the sensor and tried to combine it with a servo motor, the servo continued vibrating without any command as the heart rate sampled.
any suggestion what makes the servo work and how can I fix it?
Thank you!
JaneYu If the Heart rate Sensor can be driven by 3V3 then it would be no problem for a Raspberry Pi connection?
JaneYu Hi! Would I be able to trim off the holes for the belt to make the sensor rectangular or would that interferre with the PCB?
JaneYu Como estas buenas tardes aun dispones del sensor y que nomas incluye el envio el sensor y la pinza?
JaneYu Hi,
Can you use an Arduino UNO or MEGA and do you have a code/wiring for this project?
JaneYu Yes, you can use arduino UNO and MEGA with this. Wiring connection and sample code can be found in the product wiki page: https://www.dfrobot.com/wik...
Yes, we can send it to Argentina.
You can refer to the wiki about heart rate measurement.
JaneYu
