Are there any updated sample programs? The "Sample Code" listed under Documentations, generates segmentation errors when compiled under my desktop IDE, which could simply mean tha...
userHead JaneYu 2018-08-14 04:30:41 9 Views1 Replies
Are there any updated sample programs? The "Sample Code" listed under Documentations, generates segmentation errors when compiled under my desktop IDE, which could simply mean that my desktop IDE is outdated, so I tried the on-line IDE (create.arduino.cc/editor) thinking that it is more likely to be up-to-date and I get the following, which is only a small sample as the errors run on for pages:
/tmp/339704765/DFR0287_SampleCode_V1/DFR0287_SampleCode_V1.ino:84:113: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char *menu_strings[MENU_ITEMS] = { "LCD12864 Shield", "www.DFRobot.com", "Temperature", "Humidity" ,"About","OK"};
...and on...and on...and on...
2022-09-25 04:31:36
What controller ic does the LCD use?
