can I connect the URM04 to PC thru Ethernet to RS-485 convertor
JaneYu 2018-09-17 14:17:37 10 Views4 Replies can I connect the URM04 to PC thru Ethernet to RS-485 convertor
For anyone who is trying to get multiple sensors working, you need to program a unique address to each sensor individually/separately, only then can you join them up and use a program to get distance/temperature.
JaneYu hello your code works for a bit then stop working. do you have an updated? I am trying to connect 6 devices together, your steps does not show how I will do that. And doesnt provide the code for them? Please help
JaneYu the code being listed does not show how to connect multiple sensors together. Where in the code to add sensors?
I Really suggest updating this place if you still need people to still buy your device. Better yet make a arduino library
JaneYu Is there a module for Raspbian/Python/Raspberry Pi ?
I'll be using a Road Number LX08H USB RS485 converter.
Is there any sample Python code?
JaneYu
