Is it possible to obtain recalculated values of displacement amplitudes in the frequency domain (FFT analysis)?
JaneYu 2021-01-14 17:18:25 13 Views3 Replies Is it possible to obtain recalculated values of displacement amplitudes in the frequency domain (FFT analysis)?
2023-02-09 03:02:48
JaneYu
@disqus_zFJOmix82y:disqus
Here: Everything in this tutorial applies to this sensor too:
https://wiki.dfrobot.com/Gr...
JaneYu 2019-02-22 14:40:43
JaneYu
We did not develop sleep mode related functions in our library, you can refer to the registers used in the datasheet to develop the sleep mode function, or search online if some resource about LIS2DH sleep mode.
JaneYu 2018-10-24 11:19:50
JaneYu
Yes, you can just plug on the expansion shield without soldering. the cable is about 30cm.
JaneYu
