Do you have a torque rpm curve for the this motor you can post?
userHead JaneYu 2019-02-05 05:39:17 9 Views7 Replies
2022-11-10 08:40:49
So how long is “L” when the gear ratio is 50:1?
Also, with that specific gearbox length, what is the Overall Length of the actuator (including the solder tabs on the back end)?
2019-12-13 01:42:34
Hello, I would like to buy this XD-37GB520 12V 100rpm from you. But when I look at other websites for ratings verification, I found out a conflict. Could you please confirm these?
This has the datasheet for FH-37GB520, but it has exactly the same ratings you listed here for your XD-37GB520 at 100RPM: https://www.aliexpress.com/...
This one has the datasheet for XD-37GB520 (the one you are selling), but their ratings are different: 3.5kgcm for rated and 12kgcm for stall:
Which one are you selling? XD or FH? and does the motor come with a datasheet with the listed ratings?
2019-12-03 11:22:50
Do you carry a mounting backet for this motor?
2019-11-20 23:15:43
Hi, I am also looking for the dimensions of this motor, and what unit of measurement is used in the Motor Overall Dimension diagram? And like @GillesBisson:disqus asked, when shipped, what is the measurement of "L"? Thank you.
2019-06-14 06:09:44
Hi, is there a way I can figure out the the right speed and time delay to turn the motor to certain degrees in Arduino code. I want to write Arduino code that turns the motor 35 degrees to the left and then 70 degrees to the right and then back to the original position using this motor.
2019-04-11 03:54:47
Excuse me, How long can I get the motor after I ordered it~
Please response to me as soon as possible,
There are some limits about countries and regions.
Pls give us your order ID to this email get more detail information: [email protected].
2019-04-11 16:19:48
